1 - 8 of 8 Posts
Can someone tell me the part number for the cross member that goes thru the frame on the X700 series tractors. Is there a parts breakdown on the net somewhere? i can't seem to find it. I have found the owners manual on the JD website but not a parts manual. Thanks
The part number for the Cross tube is WP612890
Part number for lug or tube brakets WP612895
Bolts from braket to tube 19M7943 X2 + 2 14M7401 Nuts
Bolts from Brachet to Tractor frame 19M7791 X4 + 4 14M7401 Nuts
Hope this helps:thThumbsU
JD RULES
Sergeant , are these Part #'s the same for the X4xx and X5xx Series and could you Post a Picture of these Parts in their Diagram ??? Thanks in advance ...
Later,x595
here is the diagram for the 45 loader I down loaded from JD:
The part number for the Cross tube is WP612890 - 20
Part number for lug or tube brakets WP612895 - 19 (2)
Bolts from braket to tube 19M7943 X2 + 2 14M7401 Nuts - 18 (2)
Bolts from Brachet to Tractor frame 19M7791 X4 + 4 14M7401 Nu - 22 (4)
The cost for all of these parts is $330.70......Yikes.
The 45loader is the same for the X475 Thru X748 :thThumbsU
$330.00 isn't so Bad in a Year or so I might buy another X series tractor for are other Place in Henry County,IL either a X585,X595,X728 or X748 and I would just but the loader sub frame for it. So I would only have to trailer the loader a 120miles to are other place to do loader work. The other place I actually need 4WD or AWD for loader work.
JD RULES
Aeronca7CCM and Sergeant , :thanku: !!!
Later,x595
1 - 8 of 8 Posts
