I have a Yanmar YM240D with front end loader. I am new to tractors and hydraulics.
The control valve is a Salami VDM05-DD. I have not been able to find any info on this valve.
Do people generally try to repair the controls or just replace them?
Do I just disconnect the hoses from the control valve or do I need to bleed the pressure somehow?
I'm not sure about terminology so I may not describe the parts correctly. It appears that my control valve is leaking around the "piston" that the lever pushes in and out. Is it fairly easy to remove this part? And what kind of parts can I expect to replace? Just o-rings?
Thanks.
Thanks.
