1 - 2 of 2 Posts
I'm having a hard time getting the clutch to fully release because of slop in the clutch pedal assembly. Are there replaceable bushings in the frame where the shafts go through? If not how have you guys fixed this. There is also slop where the pedal pivots, close the the brake area. Thanks.
I don't believe there are bushings there, but you could easily bore it out a little and have a bushing machined. ;)
1 - 2 of 2 Posts
