1 - 2 of 2 Posts
Jd316
any idea on how much paint it will take to do a Farmall BN? trying to get an idea on how many gallons i might need. also does anyone use a clear coat or just hardener in the paint?
Weeellll, depends. How many coats, how thick... generally I'd say buy a gallon and spray it on 'till you run out, maybe save a pint or so for touchups later.
I wouldn't clearcoat it, but I would use a quality paint with hardener and activator. Talk to the guys at the paint store re budget/goals/equipment you're using and they should get you set.
1 - 2 of 2 Posts
