1 - 3 of 3 Posts
hey guys quick question. just wondering what the dimentions are for the chute rod bracket on a snowcaster. need to make one quick tommorow at work and weld it on to be functoinal for when the snow flies. thanks
Hold the crank rod where you want it when sitting on the tractor seat and measure down to the lift rod. Use 1" X 1/4" flat stock.
:fing32:
well here it is. did just that Restmycase and used 1"x1/4" flat. got lucky and welded on the correct angle and spacing to the motor tins and block fins. whew. didn't have the whole tractor to do a correct mock-up. only had the blower lift arm with. had to have a friend at work hold it in mid air while i sat on a stool simulating the riding position.
1 - 3 of 3 Posts
