Most automotive machine shops will not be able to do that, you will probably have to take it to an actual machine shop. The auto shops will not have the machine necessary to do this type of work.
Are the tabs necessary? Can't they be machined off? The crank is still going to spin in the bearing...someone correct me but the "tab" just holds the bearing case from spinning....no?One time I needed to get some LB bearings and the shop didn't have them. I went to an industrial supply house and they measured the bearings I had (old LB) and they had some that were basically identical to the LB ones, but didn't have the tabs. They were remarkably cheap, too. I think I may still have them in a can in the basement.
I think it also lets oil that pools in the channel to run into that hole to help lube the bearing.Are the tabs necessary? Can't they be machined off? The crank is still going to spin in the bearing...someone correct me but the "tab" just holds the bearing case from spinning....no?
Ah...yep I knew that so really you'll need the machined notch plus a chanel to get the lube in...makes sense. Shouldn't be too hard for a CNC with a small bit.I think it also lets oil that pools in the channel to run into that hole to help lube the bearing.
