1 - 12 of 12 Posts
· Master Lawn Cutter
Hello Everyone,
I'm seriously looking into the purchase of an expanable Pole Pruner.
I have a chain saw for the bigger jobs, but have a real need for something to go high and reach out. Do I go electric or gas....???
What do you have....and would you purchase it again.....???
I have a trusty old fiskars manual pole pruner. I find I can easily cut more than my appetite to move or chip up. It'd be nice to have a powered pole pruner but I don't need anymore equipment to maintain. I'd go electric for around the house. There's no carb to gum up and they always start.
We had a church building work day. I showed up with 2 lb hand axe, pole pruner, and a lawnboy converted to a chipper. There were 2 chainsaws that showed up. The husky ruined the chain and the stihl was hard to start. But my hand axe was much faster at limbing, and the pole pruner was much faster than a ladder and chainsaw.
Other than tractors, mowers, generator and pressure washer I have gone electric. Little wonder makes great equipment. Not engines to fuss with, no gas mix, no smoke and bad exaust to bother my asthma. I am very happy with electric. The only question is how far from power do you want to work. I do around by home, shop and barns. Everything else I hire out. There is always a good high school student willing to earn an extra dollar and do a good job.
I bought a RYOBI from Home Depot-I got the trimmer/brush cutter combination-then I bought the EXPANDIT Pole pruner that goes on it. All of the attachments work well-especially the Pole pruner-cuts clean,fast-has a third section with it that allows you to reach 11-12 feet!
The engine is easy to start-although I did turn up the idle 1/4 of a turn ,to my liking. I would recommend this setup to anyone-Thanks-AL
· AKA Moses Lawnagan
I have a Stihl pole saw, has a 8 foot reach. Can't remember the exact model, but the arm doesn't extend. It has a 4-cycle gas engine, very easy to start, and the bar is 12". It has a LOT of power for its size, I have cut limbs almost as thick as the bar is long, didn't slow it down at all. It is much quieter and doesn't use as much gas as the 2-stroke engine in my weedeater, which is a smaller engine. I have a lot of trees around my property, so I could justify the $400+ price, knowing it would get a lot of use. If I had to do it again, though, I would have stretched the budget and got the next one up, which has the extendable boom to 12'. Seems like no matter how long it is, the limb you want to cut the worst is always just out of reach.
Echo also makes a very nice pole saw, pretty much on par with the Stihl in terms of what it will do. Prices vary among dealers, but are maybe a bit less expensive than the Stihl.
One word about the 4-stroke engine. It still requires a gas-oil mix like a 2-stroke; mine uses 50:1 as do most newer ones. The engines burn cleaner than 2-strokes, and most manufacturers are phasing the 2-strokes out in favor of them. I think 4-stokes are required now in California for all utility engines.
One of the smaller ones, like the Ryobi, should be okay for occasional use and for branches no larger than your arm. I don't have any electric lawn implements, I have to go much further than I have extension cords for, and the long cords will have voltage drops (more than 50') that make the motor draw more current and heat up (shortens the motor life). You'd have to have a cord larger than 12 ga. wire to go out past 100 feet without problems, and that would be heavy and very expensive.
· Administrator - We’re all friends here
I don't mean to change the topic here but while we're discussing pole pruners, I found this guy who sells manual pole pruners that extend up to 30' long. The cool thing is that he also sells several attachments to make the pole more versatile. I have a situation where my only alternative is a very long pruner and this one fills the bill. I have spoken to him and will be ordering one today. It is a bit pricey but worth it for me. I'll review it here after I get it. You can check it out here: http://www.accu-measure.net/. :smilie_fl
I have an electric Remington pole saw and love it... nice and quiet and not used often so no carb to worry about cleaning.
Here is my follow up on the l-o-n-g pruner. I received the pole pruner very quickly but had to wait awhile to try it. You can't imagine how long a 27' pole is until you are holding it. The outer pole is fiberglass and the two inner extensions are aluminum. There are stops to prevent the poles from separating. I set it up with the rope pruner and was able to cut thin branches almost 30' high. Previously I had to climb a ladder with a 12' pole. I don't feel comfortable doing that anymore and there are places where a ladder wouldn't work. The pole also came with 2 saw blades, one of which is the sharpest blade I have ever seen. Haven't tried that yet. I also ordered a boat hook attachment so I now have no fear of losing those expensive lures in the trees. :bannana: Anyway, it worked well for me and did what I expected it to. One caveat...when fully extended it can start wobbling back and forth. I have learned to adjust my hand position or just place the butt end on the ground to stop the wobbling. I found that by moving more slowly the wobbling is minimized and not a problem. There are several other attachments available. Here again is a link for pictures or more info. :thThumbsU
Discussion Starter · #10 ·
Expandable Pole Pruners - Electric or Gas
Well, I elected to go electric. Settled on a Remington 1 1/2 hp set up.
I looked everywhere locally and came up empty. Can you believe "No electric pole pruners to be had".
I ended up getting it over the INTERNET. The price of the unit was $139, but the shipment was a killer at $29.95.
The included paper work indicated I could use a 14 AWG extension cord up to 150' without concern for the electric motor. I already have three 12 AWG 50' cords, so I didn't have to buy any cords for the three trees in the front yard.
For the five trees in the far back yard, I hooked up the Agg-Fab Yard Trailer, placed my Emergency Generator inside, along with all the needed gear, and towed everything to the back (some 500 feet away from electricity).
That setup allowed me the opportunity to trim the remaining five trees with great ease.
Something I quickly learned was the need for both the electric pole saw, and the manual pole saw (which I already had) to properly complete the job.
With the ease of the electric pole saw, I was able to cleanup (trim) eight very large trees. If the electric pole saw is never used again, I feel sure I got my money's worth of service out of it already.
I cleaned it up, re-tightened the blade and saved it till the next time. With the knowledge that when needed, it will start on the first trigger pull, and get the job done.
My purchase of the electric pole saw was the best decision I ever made.
:trink39:
It's a good thing when you can say you've gotten your money's worth after only one use. It's also good when you are happy with your purchase decision. Looks like you made the right decision. Congrats and best of luck with your new saw. :trink40:
Discussion Starter · #12 ·
Re: Expandable Pole Pruners - Electric or Gas
Yes, it was my very first use, but it was no small task. There were "many" small, and medium branches (many branches 6-9") to be removed on those eight trees.
I trimmed those trees back in 1995 when we first purchased the property. Then ignored them for some fifteen years (embarrassed). The five oak trees in the back had limbs touching the ground. To the point that we couldn't enjoy them properly.
Well, the job is done. AND that little electric pole saw can claim a lot of bragging right on the job.
Know, I think I need to replace the manual pole saw. It has a total reach of 12 feet. All the out of reach branches are small right now. If I can get to them now, the job will be easy. As they get older and thicker, the job will only increase.
I think I need a manual pole saw in the 20-24' range with a great saw blade.....!!!
1 - 12 of 12 Posts
