Have a BX 23 with a fuel gauge that is becoming increasingly unresponsive. It nominally reads “E” now, but will occasionally bump up and show the fuel level while the tractor is moving before promptly returning to “E” where it typically stays. I checked the leads on the back of the gauge under the dash. There are 4 wires, three running to the gauge terminals and a forth brown wire that provides power for the gauge light. I could not replicate the appearance of a short by wiggling the sending wires, so I assume the problem is with the sending unit on the tank and/or a connector at some intermediary point.
I tried to trace the wires to the tank to see if there is a connector that may be corroded. It is hard to follow the wires under the seat and around the pump. So, which side of the tank is the sending unit on and is there an easy way to check the leads? I’ve resorted to the good ole way (remove the filler cap and looking inside), but would like to get the gauge working again. Appreciate any and all guidance and suggestions.
