Which would you use/do
  • Rebuild of course
    Votes: 8 66.7%
  • Used engine
    Votes: 2 16.7%
  • Brand new
    Votes: 2 16.7%
1 - 6 of 6 Posts
So as i gear up to either rebuild or put new to me engines in the 3 riders i have i'm curious to poll the group. When it comes time to do something with the engine which route do you take and or why? i also throw out a third option of buying brand new, i generally dont buy new as it is usually 10 times more than what i paid for the tractor, i will admit though if the tractor was mint i would pony up the money for new.
i ask because i have a choice between buying a used engine from a scrap yard that runs for between 50 and 200 but has unknown hours on it or i can rebuild the ones i have spending who knows how much in parts. either way i'll likely pull the ones i have apart to see what can be salvaged or parted out but i'm rather curious which way most go.
This isn't Gravely specific, but I tried both routes on my Sears SS16. When the engine on the tractor went south, I first picked up a used replacement with a "dubious" history. It was the same model, and just as old, unknown hours. The replacement cost me I think $150, and lasted about another year, and then I had two old broken engines. I started looking for another one but said to myself, how many times do I want to play this game? So I spent 4-500 in parts to rebuild one of them. Yes, it was more expensive, but the thing runs beautifully now and I expect to get several thousand more hours out of it before it needs another overhaul. I wouldn't expect that from a used engine. As they say, buy once, cry once. If you can front the money and the time, I would say a solid overhaul/rebuild is the way to go. I look at replacing one old engine with another old engine as a temporary measure, as its only a matter of time before you're right back where you started. The Sears engine is an Onan twin so parts were a little spendy, but well worth it in the end.
If you have the time and the know-how (or willingness to learn) then rebuilding seems to make the most sense with most of these Gravelys. If there were a bolt-in engine that worked without crank machining or special adapters, wiring changes etc. then that's a little more tempting. With a BCS walkbehind you can typically slap on a brand new Honda GX390 for $650, but with a Gravely it's a little more involved and more costly.
You just never know what you're getting with a used engine unless it's someone you trust.
i dont have any in mind yet to rebuild, i may take the 3 kohlers i have that have holes in the block and rebuild them but havent had time yet to see if thats even possible to do.
i was just over all curious to see which way most folks go
There is no right answer to this one. The best it gets is "it depends"
For 12 horse or larger engines for a two wheel tractor, a rebuild is the most economical.
For 4 wheel tractors, if the engine is less than 16 hp, then it just isn't worth messing with. Time to upgrade to a 16 horse twin or better.
I have had good luck with used twin cylinder engines.
New engines fall into two categories.
1 - high quality and expensive with good parts availability
2 - dubious quality and cheap with parts almost non-existent. There are no twin cylinder "clones" out there. All of the china import twins are unique beasts.
1 - 6 of 6 Posts
