1 - 2 of 2 Posts
I have a CK3510SE and was running it about 45 minutes this morning plowing. It went into Regen and the regen light seemed to go off right before all this happened by a few minutes I got up from the seat of the tractor but forgot to put it in neutral causing the tractor to stall out. It now won't start and just clicks. It shows the following error on the dash
Dtc
1669
F26
Talked to the dealer and they said to disconnect the battery and reinstall it 10 minutes later to see if it clears the code otherwise they will probably need to come out to clear it with a service technician.
Knowing I have a few days before they could get to me at the earliest is there anything I could do or is it an a completely unrelated error to the regen system? (Seat switch or some other error)
Thanks
Did you try what the dealer suggested? If it works to get the tractor started, restart the regen process and see if everything clears itself up.
1 - 2 of 2 Posts
