The engine size is not going to have anything to with speed as both engines are controlled by governors although you could change it into a drag racer if you chose. I would not put that size engine on it myself strictly because there is not point in having that much horse power. I would be selling the big engine and using a smaller, cheaper engine but then since you have the engine, no problem using it. I am a trader/rebuilder, I assume you are not.
You do not say WHICH 18 hp twin you have. IF it is an opposed twin, the mounting holes will not match, you will need to measure and re-drill. Crankshaft will be the same.
Walt Conner
Walt Conner
