1 - 1 of 1 Posts
I'm in the process of doing an engine swap on a 2005 or so l110 with a kohler kt491 1 cylinder with a kohler kt715 2 cylinder. got the engine mounted and fit under the hood, new throttle cable and remounted the muffler due to longer exhaust pipes. mostly done, now trying to figure out the engine electrical connector. i can plug in the connector plug. have both engines service manuals but the electrical diagram is not very helpful. just tells me the color of the wires but not where they go to or what they do.
turning the key on makes a slight click on the engine but does not crank. on the mower side i guess i can use a multimeter on some of the connectors and see which ones are ground or battery by the key position. not sure what i would be able to do on the kohler kt715 side of the connector. Anyone know where i can get a better wiring diagram?
1 - 1 of 1 Posts
