I have a 2009 prestige with the kohler 27hp engine. Is the full throttle rpm supposed to be 3600?
Thanks for your input.
The service manual says that the power is measured at 3600rpm, didn't see anything else about max rpm setting only idle. I've usually set mine to 3400-3500. Some of the newer Kohlers like the 20hp Courage single is rated for 3300rpm max so always check.
Brad
