I just got my mower two weeks ago off a guy who had let it sit for a couple years. I cleaned out the nest in the cooling fins on the engine, replaced the magneto because the cable had been gnawed on and the plug end rusted off. I also installed a new fuel filter and fuel line. It ran mostly fine prior what I did and also before I buttoned everything up. One thing I did do was run the engine for a second to make sure the new magneto functioned correctly without the fuel line connected to the carb. Now the engine won't start, it will turn over, has spark, and fuel is getting to the carb. Could my running the engine without the fuel line caused the carb to not want to take in fuel into the bowl? Do I need to prime it in some way or is a safety switch getting me that I can't figure out. It's been a long time since I've worked on a carburetor.
The engine btw is a 16.5 hp Briggs I/C and the mower is a Yard Machines, if that can help.
Thanks!
