The problem with putting an automotive style fuel pump on is the amount of pressure that it puts out. The carb inlet needle is rated at a certain psi..Most of them when I test them pop off at 5psi.. so if your electric fuel pump puts out lets say 12psi it could push fuel past the inlet seat causing you more problems...Does this all make sense???
