I have several Echo straight shaft string trimmers. I put the heads that you line up the hole and stick the line through and wind it on. Grabbed my favorite trimmer and put new line on, in 30 seconds, the line rewound inside the head. Took it apart and 30 seconds later rewound again. Is this a common problem. Those heads are about $40 and don't want to replace it if it's a common problem?
