hi guys, before it was help with my deere 670 and now a blower my dad just got.
i don't know the history since it was bought from an auction but i can tell you that it looks like the last owner ran it with no air filter cover and possibly no air filter. this blower has 2 intake tubes going from the carb to the cylinder and both were full of crap (about 50% of the tube was cloged). i took the front tube off and cleaned but couldn't do the same to the rear as it would require disassembly of most of the blower unit but i did clean as much as i could up to the reed valve.
anyway, i've been pulling and pulling and cant get it to start. i put a new plug in it and used starting fluid and got it to sputter for a second or two a couple of times but thats it. i also removed the fuel filter incase it was clogged but still nothing.
i also took the carb apart to see if anything was damaged but didn't look like it, but then again, i don't know about carbs. also, there is some fuel/oil in the exhaust passage which i think means its running rich, i'll check that out tomorrow.
sorry for the long read but if anyone has any recommendations please let me know, at this point i'm pretty stuck.
