Probably the most expensive purchase I've made so far. Didn't need it, but wanted it.
2498548
2498547
In fairly good shape, didn't come with a bar.
Only issue is no spark. Reading up on it this seems to be the biggest downfall. Being that ignition parts are NLA this might be a shelf piece unless I can somehow source parts. Once I catch up with other projects I'll start diagnosing but I'm thinking it's either the on/off switch or the module itself, but until I get into it I won't know for certain.
  • Like
Reactions: WrongDoug
I can't help you on the spark but here's a pic. of mine with a few others. Mine will sit on the floor and idle away and never move. Amazingly smooth!. It cuts good for a bit and then dies off like it's running out of fuel. Carb re-build and new fuel filter didn't help. I even ran with the cap loose. It might be the electric issue you speak of since it seems to get worse when hot. I'm still trying!
2507191
That almost sounds like a carburetor adjustment, but then again I know the module and/or the coils are notorious for failing. Only other far fetched thought I have is the plugs are bad but I've rarely run into that.
I rarely have issues that involve spark plugs either, but I put 2 new ones in to cover the bases. I also thought it was a carb adjustment but I can't adjust this problem out of it. I'll get back to it one day.
I see you like Lawn Boy. I have 4 of them and they are all I push mow with. I love the smell of fresh cut grass and 2SO!
