I have a Ht23 that I completely took apart, sand blasted, painted restored.
When I reconnected the hydro to the hydralic lines, I did not fill the oil filter with fluid, nor do any bleeding process. The unit works now, but groans a lot, especially at low rpm. Also, the hydralic levers kind of bind up when they reach the end of travel.
I found the bleeding procedure in the eaton manual, but only after I had done the above.
Anyone know what I should do at this point?
help appreciated!
help appreciated!
