1 - 7 of 7 Posts
My current Z645 is running and mowing now.
Today I ran it about an hour at my sons house and after I got it home I decided to see how the new belt had held up. Not very well. The 2 pictures are of the same tractor supply belt.
2501532
Sensitive content, not recommended for those under 18 Show Content
2501533
I decided to take a look at the pulleys and found a lot of rust on the drive pulley.
2501534
If the rust in the pulley is not causing the premature wear I don't know what it.
Cannon
Check how freely all the pulleys/idlers/spindles rotate, and if they are all aligned properly.
Another thing to do is immediately after using the mower for awhile, after turning off the motor, feel/measure (if you have an IR gun) how warm the belt is. it should just be warm, not uncomfortable to touch doing a regular cut of a lawn (really tall, thick grass can make it hot).
I would clean that pulley up, but one if the things is that JD uses a different angle on their pulleys so aftermarket belts not having the same angle as the JD belts don't hold up well, I went through a couple of kevlar aftermarket belts on my tiller then had the JD dealer get me a JD belt and it is holding up much better.
Certified Technician
What models? Ive been selling D&D, true blue, and stens belts for deere mowers for about a decade and haven't seen any instances yet where deere didn't use a 3L/4L/5L section belt with the exception of the General Trans models that require the oem belt from GT.
I ordered new pulleys for the engine and pump, I can feel a ridge on both of them. The idler looks ok for now. Both are aftermarket from Phoenix Mfg, they were both a lot less expensive than OE. I'll get another Tractor Supply belt when I put it back together.
Cannon
All of them Red. But there are several aftermarket belt manufacturers who do have belts with that angle. In fact many on the JD website have an "alternate" (cheaper) belt available.
2501798
2501799
Right but using that example, deck belt for a 38" deck on a 200 series, 316, 318, 322, 332...
Oem number M82538
Comes up as a 1/2" wide 64"od belt with no listed additional special dimensions.
Crossed to:
  • Rotary - 7507
  • Laser - 95547
  • Sunbelt - B1A62K
  • Stens - 248-064
That stens belt also crosses to about 45 oem belts of the same size.
I just don't see anything unique about deere pulleys or belts vs other brands. I can't fathom the expense of tooling up a special line purely to make unique pulleys, belts...for 1 manufacturer.
Ill do some digging...
1 - 7 of 7 Posts
