As you can see by the pictures the lever is broken. But once I fix it, just what does that lever do. I started to work on it and had to fix a few small things before I could try to start it. But once I put the battery in, it started like it had just been running. It has a good oil leak in the front of the engine that I will have to check out and see what is leaking. But I took it for a test drive and everything seams to work okay. So you guys with the old John Deeres please let me know what the lever is for. Thanks
