1 - 8 of 8 Posts
Old Iron......Forever
I'm looking at this Earthcavator, and it isn't a very good photo. It is a for a GT, and I'll be going to look it over. Any comments about it and the likely model of it, chime in.....
Looks like one I have. Mine was sold by Sears configured for the proprietary Sears 3 point. I took the top link connection off and weld up a cat 0 configuration. Awesome little blade. Just wish it was 4 instead of 3 feet wide.
Yes it for a GT. I belive it was made by Gannon:thThumbsU
USMC
Looks to be made for the Sears 3 point (narrow) and yes that was made by Gannon, and they work AWSOME!
It wouldn't be difficult to modify it for a standard Cat-0 3-pt setup.
If you cut off all of that forward-facing arms and such that are welded to the front of the angle iron, then weld on some mounting ears and an upright similar to this:
http://www.weekendfreedommachines.com/gallery/main.php?g2_itemId=94026
20" apart for the arms, and 12" center-to-center from that center line to the top eye of the mast.
hankll,
As to your concern about the release handle, it is there, the scraper is upside-down in the pic, and it is underneath on the right. One of the bolts has been removed, and the arm folded back.
Discussion Starter · #8 ·
Got the measurements as 20" or 10" from center to outer point for the first of the two ears for the pins to go through?, and right in center 12" tall to the top of the mast. All with 5/8" holes. And now that you point it out, I see it. And now I do see that the Vator is upside down.
Owner is out of the country until the 23rd of this month. He says he'll call me when he gets back. I let him know I was waiting for his call. I don't have a good stick welder hook up yet, so I'll have to show my welding shop guy what I want. Course I didn't mention the welder guy, so I could brag on my own welding prowess, NOT! I have a wire feed welder, and it isn't heavy enough for this type of welding. My stick welder is 220, and I don't have the wiring run out to my shop for it, yet.
If this guy sells it out from under me, I'm going to be sick.
1 - 8 of 8 Posts
