I'm sure others will chime in about the gap in the clutch. My Husqvarna did this and I found out that the clutch was full of dirt build up and grass. Once I cleaned it all out with the air hose and learned that two much gap creates high amp draw and blow fuses and later on would eventually take out the PTO switch. Grab your feeler gauges and check the gap. I want to say 12 to 14 thousands of an inch, but I can't remember right now. I have it written down in a book somewhere. Hopefully your clutch is adjustable and it's easy to do.
