1 - 6 of 6 Posts
I just obtained a Dynamark 15.5 Tecumseh/42 mower from a buddy. The mower is in great shape but the motor siezed up after it was run dry of oil. How can i figure out which motors will swap in? I have an MTD with a 16hp (briggs)donor, but would like to research whether it will fit prior to attempting the swap.
Thanks (i'm a rookie)
Dave
Dave,
Welcome to MTF. Is this a Murray built Dynamark? can you post a model # or a picture? A couple stumbling blocks in an engine swap can be bolt patterns to attach it to the tractor, wiring harness differences and stack pulley [the pulleys that drive the blade and trans belts] sizes.
I'm not sure about bolt patterns. I would imagine you could always drill new mounting holes if need be. The bigger concern may be shaft length and diameter. This might be a better question in the Backyard Round Table forum, it will get more eyes on it there.
BBY
1 - 6 of 6 Posts
