I recently picked up a JD 165 hydro for cheap cause it had a couple broken belts. I replaced all 3 belts and when I fired it up, it almost took off on me. I realized the forward/reverse lever was in the forward position and it was moving without pressing the pedal. Is the brake/neutral pedal on the 165 supposed to also be a forward/reverse pedal like on most hydro tractors or do they normally just go when you put the lever in forward or reverse? I’m assuming there might be an adjustment somewhere but I can’t find it.
I also noticed the brake doesn’t work anymore since I dropped the axle down a little to replace the hydro fan. Hoping I didn’t mess something up with that…it was working fine before.
Any help is much appreciated!
