Driveway rock
7691 Views 29 Replies 10 Participants Last post by  forkz
So we have some new property as of 3 today! We have a 500' right of way. It has some stone as a base. It's the large fist size. But now I need to put some base down. Late this summer/fall I'll end up black topping it. So, my question is: what do I put down now that will act as a good drive way while I work out there, begin to build two houses in the spring and will serve as a base for black top?
21 - 30 of 30 Posts
We hear use what is called crush and run, 3/4" blue stone with some kind of filler and it works very well. We have lots of hills so about every 4-6 months it has to be scraped back up. My driveway is 200' and after 7 years I just had to lay down another 6 tons and could use some more. Some nut:howdy: planted trees so the big 25 ton truck can no longer make it to the driveway so I have to buy it in smaller loads. Price was $18.50 per ton.
Stone dust is the 'filler' in the 21 A or B (which is crush/run) that you are talking about...the dust , when wet--is what adheres and holds it all together....You want the big stone on the bottom--then the base wil eventually sift down thru it....
Different names in different areas.....:dunno:
glenn
I think crush and run maybe my best and/or cheapest option since I have to buy so much. So.......should I put down the fabric? How thick should I lay this batch? 12' a typcial width?
And thank you JBrumberg. The ole 790 did a great job this weekend. Need to get my hands on my father in laws 7' grader blade to really finish it up.
If I remember correctly the woven geotextile material was 15' wide. It was laid as a single sheet with 2' seam overlaps. We pinned it down as it was laid.
Decision time. My choice is #57's at $21.75 a ton or crushed concrete at $16.75 a ton. 57s can be tailgated in meaning alot less work for me. The CC can't. He can do small piles though. I can spread it, but.....
So, not sure what to do. Any thoughts? I'm even thinking about haggling the price down on the CC. Took them a while to get me a price. One concern I have with the CC is it taking more tonnage because of the dust in it.
depending on your soil the rocks are always going to sift down it takes years to build up a good base, but luckily i have shale
I have the base, so this would just be a topping.
glenn
we call it screenins here i got a load of just dust packs hard but it tracks bad sticks to shoes that ditch will make a big diffrence thres a church 2 house over thay have metal building in the back that when it came a lotta rain it would seep tru the floor well they wanted to dig ditch acroos nieghbors property n ours but nobody could agree how my dad told them to start with how to do it they wanted to dig a ugly ditch n leave it dad said no he wanted it right finly they agreed on v ditch a little bit deeper as they went made a world of difference people on the other said it made it a lot better to
Got a lot done today. Had 76.14 tons of #57 limestone delievered. The guy did a great job tailgating it in and then I worked for about an hour evening everything out with the bucket and grader blade. We bought two rolls of the road fabric and I'm glad we did. Those totaled 600' together, could have used another 100 feet, but we're good.
looks nice josh
21 - 30 of 30 Posts
