Drive Belt Adjustment
1506 Views 2 Replies 2 Participants Last post by  tharbin14
So I just picked up a 1978 Bolens G11xl the other day and have resolved all its little gremlins but one. It runs great and will drive but is most responsive in 1st and Reverse. It will go in other gears but its a struggle. It shifts very smooth and doesn't grind at all. I dropped the mower deck and climbed underneath. It has a shaft coming directly off of the flywheel side of the engine that connects to what must be a worm drive with a pulley for the drive belt. The drive belt rides on three pulleys, one on the worm drive, a second on the transmission and third on a tensioner pulley. When I operate the clutch/brake pedal I can see the tensioner pulley move back and forth to give and take slack away from the belt but it appears to be pretty loose in either position. When in gear I can smell burning rubber telling me that belt is slipping but I cant figure out how to adjust it. There was two rods coming from the back by the transmission and connecting at the clutch/brake pedal. Both were threaded on the end and one had two adjustment nuts on it. When I adjusted it all it did was reduce travel of the pedal and the other rod seems to be stuck in its current position with the adjustment nut being about an inch away from the point of contact between the rod and clutch/brake. The nut appears only to prevent it from falling off and I'm not sure that any adjustment of it would matter anyways. If I'm missing something please let me know.
1 - 3 of 3 Posts
The tensioner should be the adjustment. Either the belt is worn too much or the tensioner spring is weak or wrong. I would have to guess belt is bad if your spelling it burning.I
I managed to get it goin this morning. I decided I wanted a little more room to work so I pulled the seat and rear fender to give myself easy access to the linkage and belt. I found a complete breakdown of the tractor and those two rods I mentioned earlier are the clutch rod and brake rod. It was the clutch rod that I mentioned appeared to be stuck. I believe it had spent some time parked with the brake set and locked in position long enough to have rusted itself in place. I had previously tried to tap it loose with a hammer but had too little room to work. After pulling the fender I pulled the cotter pin at the other end of the rod and popped it out of the bracket and it immediately became clear that this was the problem. It freed up very easily with just a quick turn back and forth with a pair of channel locks and now its working very well. Plenty of go in all gears enough to just about put your hair back.
1 - 3 of 3 Posts
