Still not posi (limited slip) There IS a diff-lock pedal though. (which actually locks the rear differential.)Only the GX 345 and then only on the '04 and '05 models.
Seems pretty rare for any garden tractors to have an actual "posi" or limited slip differential. Typically they are either a standard open differential or have full locking capability (by pushing a pedal or switch). Maybe people are confusing posi and locking differential to be the same? Concept is similar with a "posi" only able to supply a certain percentage of power to one side (meaning under certain conditions you still get one wheel peel) where as a locking differential both sides are 100% locked together.
Certain year simplicity's have a k61-65 with a limited slip. I just swapped one into my xt1 cubPosi LOL!!
I'm not saying you are wrong as far as a garden tractor goes (as I'm the 1st to admit that I am far from being an expert on the inner workings of them), but that is not the case in a truck rear end with a limited slip(posi) transmission. As in a truck limited slip, once a wheel starts to spin, more torque pressure is sent to the opposite (stationary) rear wheel to help propel the vehicle forward.Seems pretty rare for any garden tractors to have an actual "posi" or limited slip differential. Typically they are either a standard open differential or have full locking capability (by pushing a pedal or switch). Maybe people are confusing posi and locking differential to be the same? Concept is similar with a "posi" only able to supply a certain percentage of power to one side (meaning under certain conditions you still get one wheel peel) where as a locking differential both sides are 100% locked together.
Back at my old house, I had the same problem when I mowed my pond damm. I ended up getting a set of bar tires loaded with RV antifreeze, added wheel weights and weight to the front. No more slipping going up or down.You obviously do not mow a 1 acre steep hill, as it is quite common to spin out.![]()
I think we are basically saying the same thing in regards to how a "posi" works. By the way, "posi" or "Posi-Traction" is actually a specific brand of a limited slip differential as coined by GM a long time ago. There are several different styles of limited slip differentials that use different methods to transfer power to the wheel with traction. Spring loaded clutches, torque biasing/torsion style, etc...and different levels of "power transfer".I'm not saying you are wrong as far as a garden tractor goes (as I'm the 1st to admit that I am far from being an expert on the inner workings of them), but that is not the case in a truck rear end with a limited slip(posi) transmission. As in a truck limited slip, once a wheel starts to spin, more torque pressure is sent to the opposite (stationary) rear wheel to help propel the vehicle forward.
Gentlemen, thank you for answering my initial question.
The reason I asked is that I live on a hill, when its wet ground or ice on the driveway(even on dry ground at steepest areas), posi traction sure would be of help to limit the spinning.
