.......Run's fine for 5 minutes or 20 minutes, 2 hours or sometimes all day, but at some point it will just cut off like someone turned the key off.
It usually cranks right up again immediately and runs fine until it cuts off again later on.
It must be something electrical.
When it does cut off, it's off like a switch...no starving of fuel.
Thank You,
Rod
Pamlico Lawn Care, LLC
Oriental, NC
Yep, your right, sounds electrical....exact same signs my OH160 did when the SSI module went out.....two of them, both did same thing, sometimes for hours, other times for a few mins before they cut out. I figured mine out by keeping a plug wrench on me, as soon as she died, I pulled plug and checked for spark...nothing. Let it cool for 5-10 mins, would start right back up until they both finally died and wouldn't start again.
There should be 3 wires coming from behind flywheel through a connector up to regulator and the middle wire going to the switch. When it dies, unplug that connector and see if you you get fire. If you do, then it's a switch issue and needs replaced. If still no fire, then most likely that module is getting hot and no working. Have to make sure if you replace switch you get correct one, the switches on these ground out the module when you turn it off. Wrong switch and you could posibly send 12 volts to module and burn it up.
Check all connections first, that's easy route.
There is also a small wire that should come up from under the flywheel in the front, that gives the module it's juice. Sometimes they get chaffed and ground out module. Yours possibly could be doing that when ya hit a bump shutting motor down, then starts back up when you try.
....I'm still thinking your module is on it's way out though, but if it is, there is solutions out there without paying $200+ for a used 35 yr old module on evilbay.
