Makes you wonder about some people..
OP is back
Wow, thanks so much for all the responses, people! I've learned a lot more about tractors just by reading through this - I thought all I needed was a little bit more HP!
I'm trying to upload some pictures of my place for more info, but it looks like there's an error/it isn't going through! I'll keep trying.
To clarify some things, there's a little bit of a grade (probably 20 degrees) on the backyard lawn. There's a bit of a larger slope (30-35 degrees) on a driveway going up from the backyard to the front - and if I'm hauling things, I'll be hauling them up the hill to the front, rather than down the hill.
The attachments I'm looking at right now include a dethatcher, and a sweeper (loads of trees shedding on my back lawn). In the future I might get an aerator, I just don't know how often I'll use it and whether it's worth the cost (vs. renting).
I guess I should be looking outside of big box stores like Home Depot and Lowes, so I'll try taking a trip to a local distributor for John Deere! Although online they have a $300 off deal on their X300 series, so I might just consider an X330 - will have to think about it!
Meanwhile, I'll try posting some pics today - maybe I can get it to work somehow. Thanks again everyone!
OP is back
Slope / angle is difficult to judge. 30deg is very steep. It feels a lot steeper than what the number would suggest.
So lets look at some pics.. if possible try tp get a frame of reference intp the pic - like a piece of flat ground, or a vertical tree
Maximum angle of repose for dirt or gravel - 39° (The slope of a pile at the end of a conveyor.)
Angle of a typical 4/12 pitch house roof - 18.4°
Maximum slope for an interstate highway - 3.8° (6% grade)
Lawn tractor hydros will have a shortened life span if used regularly on slopes exceeding 7°.
Few people can guesstimate a yard's slope with any degree of accuracy without a known reference.
To the OP, lawn tractors (LT) such as found at the big box stores, including JD X3xx models, have hydros which can deliver up to 3 hp to the ground, no matter what size engine is in the tractor. Garden tractors (GT) have hydros which can deliver, depending on the model of hydro, from about 3.5 - 5.5 hp for entry level and up to 11 hp for the heavy duty hydros. For a 30° slope, you want a heavy duty hydro if you want the tractor to last for more than a few years.
Hey Folks! I'm new to this forum
I'm in an analysis paralysis - I'll explain my situation and hope I can get some advice from you all.
I just bought a new house on a hill in a semi-dense suburban area, where the front yard is pretty small (would take 15-20 mins mowing with a self propelled mower) but the back yard is (1) relatively larger, (2) down a hill and uneven, and (3) needs a lot of work.
The backyard is divided into two spaces - an actual lawn, probably 5000-7000 sqft and slightly hilly, and a green space with large trees and English Ivy ground cover (which I want to get rid of because it's killing the trees). The actual land I own is 0.75 acres; out of which maybe half is green space.
There's a lot of work which makes me want to get a tractor - hauling wood/branches out of the green space as I try to clear it up (and take it up the hill to dispose), dethatching my lawn since it's covered in moss and dead branches, and obviously mowing. I also kind of want a tractor because I think it'll be more fun + a lot quicker than regular mowing - I don't want to spend all my weekends in the garden/lawn, but it's really expensive to get someone to come and mow every other week here ($70 a mow in Seattle).
Just wondering.... does it make sense to buy an entry-level lawn tractor like the JD S120? It's got a 42" deck but 22HP which I think would be useful for all the stuff I want to haul. I do have the space to store it. Or is it overkill, and I should just buy a ~$500 mower and call it a day?
Good point Tudor and frame of reference.
Not to seem redundant but it seems the OPs needs should be more centered on safety, not what hydro will stand steep slopes.
OP is back
Well we should always be centered on safety. Safety has little to do with two wheel or four wheel drive on slopes but more to do with center of gravity. I have watched two wheel drive equipment operate safely on slopes you could not walk on. It is all about maintaining center of gravity.
