Well as Others Have said Don't go with a entry Level Lawn tractor i.e one that You Can Buy at a Box store Like Home depot or Lowe's All But the Top two Models S170 & S180 Have a TL-200 Transmission same as the Previous T40J Those are really designed for a Rear engine Rider and There Usually fine if Your Yard is Flat as a Pancake and You Have a 1/2 acre or Under The S170 & S180 Have a K46 Transmission the same You will find in the S240, X330, X350, X350R & X354AWS There fine for Flat Yards & rolling Hills for Mowing and some snow removal again as long as it not a really steep hill the X300 listed Can be Just fine for Under a acre The X370 Had a K57 which is basically a K46 with a Bigger charge Pump( But the Transmission is serviceable Meaning You Can change the Transmission fluid while the Transmission is on the Tractor) then the X380 thru X394 Have a K58 Transmission The X390 & X394 Models Have a serviceable transmission like I stated earlier.
The Next Deere series is the X500 series which is 2WD with a K72 which is Basically the top of the Line Belt driven Transmission all transmission our serviceable all But the X570 Have replaceable internal filters The X570 is your Basic Deere Garden tractor with Manual spring assist footed Pedal lift for Mid and front and rear Implements Cant get a electric Lift Kit for a Front Blade or snow Blower The X570 also Had manual steer
The X580, X584 & X590 Besides the serviceable K72 with Internal filter They Have Hydraulic lift for Mid and front and rear Implements and Hydraulic Power steering the X584 also has All Wheel Steer(great if You Have a Lot of Obstacles to Mow around But are Limited In rear Implements such as it Can Use a OEM rear Mounted PTO or Hydraulic driven tiller.
Based On Your Use I am Not Going to Talk about the X700 series I own a X748 older Version of a X758 But think either would be overkill for your Intended uses
The Cub Cadet XT3 series as Mentioned above Very Capable Tractor
XT3 GS is You No thrills Garden tractor It Is Manual lift for Mowing decks and Front Blades and Manual steer It Can support up to a 54inch Fabricated deck I would try the OEM 60inch deck. Though it's listed as fitting even with the onboard Spring assist it is a Bare to lift
XT3 GSX Has electric lift for Mowing decks and front Blade It has a choice of 6 Mowing decks a Stamped 42, 50 & 54inch deck or a Fabricated 48, 54 or 60inch deck. This Model also Had Electronic Power steering. On Hand Operated Diff/lock Many of the PTO Mounted Implements for it our aftermarket PTO Tillers, Rotary Brooms ect
I own a Cub Cadet XT3 GSX Myself Been a Great tractor for the 2 & 1/2 years I have owned it Just used it for snow removal as well this past winter which it think might be over in North East Illinois
My Plans for the XT3 GSX is to add a Bercomac 30inch PTO tiller and a front Mounted Rotary Broom finally this year
What I Like about the XT3 series is the Fact you have so Many Mowing decks sizes.
The Other Cub Cadet I would recommend Looking at is a Cub Cadet XT2 GX54 D Has a Kawasaki engine as of 2021, Rear Pedal Operated Diff/lock with a K62 transmission
Somebody Mention the Kubota GR series That is a issue Prone series for Kubota it's Basically a dressed Up Lawn Tractor with AWD and something Like All wheel steer a lot of Issue with there steering system
Kubota that I would recommend for Your Intended use is a Kubota T2290KWT48 It has a Proven Garden tractor Transmission in it a Hydro Gear G730 Thought it is sold as a Lawn Tractor comes with a 48inch deck a Kawasaki engine Great all around Lawn tractor But it's Price In in the Cub Cadet XT3 series Price range
I would even recommend Simplicity a Boardmoor( K58 or K62) , Conquest(K66) or Prestige(K72) That a K58 to a K72 Transmission all have a Automatic Traction control The Conquest and Prestige Have diff/lock as well some Conquest Models have Hydraulic Lift and electronic Power steering The Prestige has Hydraulic Lift , Hydraulic Power steering some of the Boardmoor Model Have Both Hydraulic Lift and electronic Power steering
Cub Cadet
Cub Cadet
www.cubcadet.com
John Deere
The Select Series X300 Lawn Mowers from John Deere - maneuverability masters designed for homeowners who mow up to 3.5 acres and have varied terrain and light-to-moderate yard tasks.
www.deere.com
The Select Series X500 Multi-Terrain Lawn Mowers from John Deere – multi-terrain and multi-talented. Mow where you need to go and do heavy-duty work, too. Explore the different models in this series.
www.deere.com
Kubota
Browse through Kubota's T2290KWT-48 Lawn & Garden Tractors tractor inventory, filter search by features to find the best fit for you, or even build your own. Then find a dealer close by with your desired product!
www.kubotausa.com
Simplicity
Simplicity makes top-of-the-line, heavy duty garden and lawn tractors for home landscape enthusiasts and for those who want a professional-looking lawn.
www.simplicitymfg.com
Just some Brands and Model for thought to support a Hilly 3/4 acre Lot
