I have a 1977 briggs and stratton 16HP opposed twin horizontal shaft engine (Model #: 401417, Type #: 0127-01, and Code #:77122112). the need to replace the points magneto with a Magnatron magneto because the points are burnt beyond repair and briggs no longer makes a replacement points assimably. I need to know... Does the engine use the same flywheel for both points and Magnatron ignition? Also it looks like the flywheel that's on the engine now is a replacement so if there are different flywheels, how do I tell them apart?
