I've got a Dixon ZTR 4423 here in my shop that is sluggish on the left side drive. The customer stated he had a broken sprocket on the left side and replaced it. Since then the left side appears slower to move forward than the right side. I've tried adjusting the transmission per the factory manual with no success. Finally decided to pull the transmission out of the machine---boy, what a job!!! Looks like the lower cone is somewhat more worn than the upper. Maybe the problem--although he said it worked "fine" before the sprocket broke.
Also, the smaller drive chains that go from the transmission to the wheel drive sprockets appear to be loose--much more on the left than right. And, to top it all off, there's no adjustment for the chains. This machine was well taken care of and I'd expect something like this in a well worn unit. Anyone out there with any experience on these?
Thanks!
Tom
Thanks!
Tom
