1 - 8 of 8 Posts
I made my 45 loader a skid steer quick attach system, so I could use proper forks. That worked well. Now I want a grapple. I have a summit hydraulics diverter valve that I want to split the curl function. Has anyone brainstormed ways to mount this conveniently on the tractor without tearing into the hydraulics further than the ports? Or would it be better to mount the diverter on the loader itself? Any ideas appreciated!
2484513
2484515
Following. Is do this on my x595 and maybe in my 2305.
What shell is that? Looks clean.
Sorry, I'm a little slow - What shell are you referring to?
I've decided to mount it on the loader itself, seems simpler, and easier to transfer to a new machine when I can find myself an x595 or x748! Will post pictures along the way.
I have the artillian on my 2205 deere it was a kit that had everything as far as installation the electrical was the hardest part.
Doug
Sent from my SM-G960U using Tapatalk
Doug
Oh wow, really? I thought you just run ground and power from a switch to the valve, and when power is switched on, the valve is open, off - the valve is closed.
Discussion Starter · #8 ·
Valve is in and works perfect! Added a joystick and threw a button on that to control the valve. Here's some pictures if anyone is looking to do this and stumbles on this thread. Just have to clean up the 3rd function quick-connect mounts on the loader crossbeam.
2487045
2487046
2487047
2487048
2487049
1 - 8 of 8 Posts
