1 - 8 of 8 Posts
外人Geezer MTF Member
I found this 4' tandem disk for $250; seems like a good price, but will my JD 2210 handle it okay?
Deere 330 Killer
i would tend to think so, as long as you have weight
My guess is your 2210 will pull that and you won't even know its behind you. A few years ago I pulled 6' set of disks with 2 double rows of disks with my old 650 4x4.
外人Geezer MTF Member
Thanks, guys. I might just get this one... Now, all I will need is a trailer to haul all me things around in! And, TG, great to know someone who actually has used one with a 2210.
Mine is a old ford N series 5 foot 6 inch wide set.. 22 inch disks double gang .. if i don't hang 5, 42 lb weights off the front it will lift the front of my 2210.. With that four foot set you will be fine..
外人Geezer MTF Member
My 2210 has a full set of the suit case weights that came on it when I bought the tractor; now, if I just had a fall deer food plot to use it on... Maybe I need to rent myself out; I actually like doing this stuff so much, I would just about do it for free! Mind you, I am new to all this tractor/disking/cutting stuff. But it sure is fun!
Perfect match for your 2210. I have a frontier 4 foot disc harrow I use with my 2305. I do hire my work out. It can be very rewarding especially in the spring. I have done some deer plots for different folks. I have a 4 foot bushogg also along with JD 647 tiller,FEl,62" mmm, 4 foot BB.
1 - 8 of 8 Posts
