1 - 3 of 3 Posts
Original spec is for 80w90 but you can use UTF if you want. Some folks use UTF in case there might be a leak between the hydraulic and differential housings. The 80w90 if you use that can be GL5 since there is no yellow metal issues with the NAA diff.
1 - 3 of 3 Posts
