The K57 is based on, and just as serviceable as, the K46. It will last longer because the charge pump takes over the duty of pulling fluid from the reservoir to replenish losses in the hydro pump and motor. In the process, it improves the performance of the hydro by a very slight margin.
It's still inadequate for slopes for a long life expectancy, as is the K58 which is serviceable, has a more robust final drive, and has the options of a filter and implement lift hydraulics.
All 3 hydros use the same small size pumps and motors which means that pressures are going to be high when dealing with slopes, and high pressure means high heat generation and increased wear.
