Diesel Fuel Storage revisited
6450 Views 16 Replies 10 Participants Last post by  saskman49
I guess I am part lazy and also wanting a good solution so the wife can fuel the 2320 if she would ever need to as she cannot lift the 5 Gallon diesel cans up to fill the tractor and I am less than excited abt where the fuel cap is as well and have spilled my share of fuel over the tractor. So I bought a slip tank like the one in the included pic with a hand pump on it and hence the next question.. I have used approx 25 to 30 gallons of diesel since spring and will probably use another 15 to 20 till winter based on current trends, over winter the use could vary from 5 gallons to who knows due to weather trends. So the question is should I suck it up and continue using the 5 gallon cans or use the 100 Gallon slip tank. I am aware of the water thing but are there not additives for that issue and adding a filter at the outlet of the pump to ensure clean fuel gets to the tractor. Also assuming I were to go with the slip tank, should I wait till Oct and get winter blend or just fill the tank and add the proper additives to ensure it will survive in our climate (-30 or so for extended periods). Also can you fill a diesel storage tank to like 1/2 full and just keep topping it to that point (Cause it would be less than full most of the time anyway). That way I could use the loader to put the tank in the truck to take it to town and fill it to the required level as no fuel dealer would come to fill it as it would always be less than 100gal.
Thanks
1 - 17 of 17 Posts
don't have to worry abotu diesel gelling here, so i can't help with that part. i like the idea of a large tank myself, you never know when you will need fuel for an extended period of time, personally i would go with the tank and hand pump.
the other option would be to just fill the 2320 up yourself each time you used it. then it is always sitting there with a full tank. edit to add: this option may be better, cause if your wife is like mine the tractor would run out of fuel at the furthest point on the property from the tank! i swear she think E means enough.
I always top it up every time she has used it only because she can't lift the cans. She really likes being self sufficient and hates it that I have to fuel the tractor for her. Also sometimes it limits what she can do in a day as she can only go till she sees the fuel is getting low then has to wait till I get home.
I would just put 20 gallons in it for now and locate it in a shady spot as this should reduce the condensation rather than having the sun beat down on it. Then put another 20 of winter blend in October. You can always add conditioner to the first 20 gallons if it was not used prior to "winter setting in".
I would definately want the filter as you suggested.
Jake
Wix makes a nice water seperator/filter setup thats only about 35 bucks--it uses the same number filter as my 82 GMC does for the prinmary filter and it has the drain petcock on the bottom to drain any water out..it comes with a base for the spin on filter with 1/2" pipe threaded ports..(I'd give the part # but my Wix book is out in the garage!)...we used one on our bulk diesel tank at the junkyard for the forkloader and other diesel equipment (old buoy from the ocean converted to a fuel tank!)--it did a great job of keeping water out of the engines,and we drained plenty of it from the filter often,since the storage tank was rarely more than 1/4-1/2 full and was in the sun and shade about half the day each..
Bought this today for 39.99 Cdn. SHould do the job I hope.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_350494_350494
saskman49 , I use and suggest for your storage , Power Service in the white bottle , fill your 100 gallon tank , add the additive per directions and forget about it IMO ...
Later,x595
Paul,
I understand your statement however around here I see my neighbors with 500+ gallon fuel stands and although their tractors and combines obviously use far more fuel than I their equipment sometimes sits for 8 or 10 months like the combines and sprayers. As well the fuel stands sit unused for probably 6 months of the year after harvest except for the possible top up of a tractor over the winter for snow removal duties. So I guess my issue is these people don't drain their tanks and for obvious reasons can't as they certanly cannot fill a Deere 9000 series tractor from a jerry can nor would they leave them empty.
I guess the smart money would say I should really ask my neighbor what he does.
Looking at your tank, I'd guess you could probably add a desiccant breather cartridge. These keep moisture (and contaminates) out of the tank as it breathes. Here's a quick article I found on the topic:
http://www.machinerylubrication.com/article_detail.asp?articleid=816
These do add a maintenance point for your tank, as they don't last forever. I'm also not sure how expensive they are. For a low flow rate application like a small fuel tank, you won't need a large one, and shouldn't have to change it often. Just a thought...
Well, I decided to do the smart thing and do as the Romans do. I called my neighbor last night and discussed this issue with him and this is what I am going to get today.. Just have to buy it in a case as they are bulk dealers only. I will put the winter additive in later if I have any summer fuel left. He says all the farmers around us use this stuff. He bought an old white 45hp 3cylinder for yard use a couple years ago and when he got it it ran pretty rough with the exh always seeming wet. After a few tanks with this stuff it has smoothed out and burns much cleaner.
Texas Refinery Corp.
Lubricants
DZL-LENE XL/10
  • SUPERIOR FUEL INJECTION CLEANLINESS
  • IMPROVED FUEL ECONOMY
  • ADVANCED LUBRICATION PACKAGE
  • REDUCES EXHAUST EMISSIONS
  • STABILIZED FUEL STORAGE & CORROSION PROTECTION
  • PREVENTS THE FORMATION OF FUEL/WATER EMULSIONS
Whether you operate on road or off road, DZL-LENE XL/10 protects your equipment and your pocketbookWhether you operate off-road or on-road, gasoline or diesel equipment, DZL-LENE XL/10 provides a cost-effective way to improve fuel quality, reduce deposits, lower emissions and improve engine performance.
Superior Fuel Injection Cleanliness
Original Equipment Manufacturers have recognized the value of strong detergent additives, to increase engine durability and operating performance. Clean injectors help maintain maximum combustion efficiency, which increases fuel economy and maintains power, when compared to an engine running on untreated fuel.
Cummins Engine Co. devised a test to measure the effects of fuels and additives in heavy-duty, direct-injection diesel engines, as it goes through loaded and unloaded cycles. In the Cummins L10 Injector Depositing test, the "XL/10" additive package has shown strong, consistent performance in both high and low-sulfur fuels and received a "Superior" Rating.
Also, it helped to achieve a 63% improvement in the CRC Plunger Rating, when comparing low sulfur fuel treated with DZL-LENE XL/10, to an untreated fuel and exceeds the performance standards outlined by the Engine Manufacturers Association, allowing the engine to operate as designed throughout the life of the engine.
Improved Fuel Economy
One of the benefits of the injector cleanliness, achieved with DZL-LENE XL/10, is maximum combustion efficiency. By obtaining efficient combustion, it has been found that it can improve fuel economy by as much as 6.5%.
Used at a rate of one gallon to 500 gallons of diesel fuel . . . or one gallon to 400 gallons of gasoline, it proves very inexpensive to use. As a matter of fact, it can actually pay for itself with fuel efficiency savings and a cleaner running engine.
To determine the amount in ounces, to use in a known amount of fuel, use the following multipliers: .256for Diesel for1:500.32for Gasoline for1:400.64for Gasoline for1:2001.024for Gasoline for1:125
Examples:
20 gal. Diesel x .256 = 5.12 oz. DZL-LENE XL/10 9 gal. Gasoline x .32 = 2.88 oz. DZL-LENE XL/10
Advanced Lubrication Package
Contains a special lubricity agent that meets the lubricity requirements of injector pump manufacturers. It's a heavy oil based product, and unlike an alcohol based product which is drying, itcan provide needed lubrication to the upper cylinder and ring zone area of an engine. The special lubricity agent will protect the fuel pump and injectors from wear and scuffing, providing long, trouble-free operation.
Important preventive maintenance product for today's gasoline Port Fuel Injected engines. The Advanced "XL/10" package not only cleans the PFI systems, but keeps them clean. Port Fuel Injectors can be cleaned after three tanks of fuel, at a treat ratio of 1 gallon to 200 gallons gasoline. Expect one tank to clean Port Fuel Injectors at a ratio of 1 gallon to 125 gallons gasoline.
Reduced Exhaust Emissions
Legislative and environmental concerns worldwide are driving the builders of equipment to comply with more stringent regulations concerning today's engines. The drive is toward high performance, while attempting to control emissions.
Can help to reduce exhaust emissions. Performance tests have shown as much as a 16% reduction in hydrocarbons, a 1.7% reduction in nitrogen oxides, a 19.7% reduction in carbon monoxide and an 11% reduction in particulate.
Stabilized Fuel Storage & Corrosion Protection
Provides additional protection against oxidation, to maintain fuel stability and prevent deposits, sludge and filter plugging. Operation costs will be reduced and engine maintenance will be decreased.
Corrosion of fuel system components can reduce engine life, increase maintenance costs and harm engine performance. DZL-LENE XL/10, with special corrosion inhibitors, helps protect fuel systems from rust and corrosion, as tested in the National Association of Corrosion Engineers Rust Test.
Prevents The Formation Of Fuel/Water Emulsions
Contains special additives to deal with the every day condensation that builds up and occurs in storage tanks and vehicle tanks. A special demulsifier has been added, so when water in fuel is excessive, an emulsion formation is prevented. This keeps fuel flowing freely and allows free water to be drained from fuel storage tanks during regular maintenance. In vehicle tanks, where the fuel is recirculated, this product allows a controlled amount of moisture to be absorbed and harmlessly burned with the fuel, keeping the vehicle tank dry.
Poor Spray Pattern caused by carbon build-up in Port Fuel Injector prior to DZL-LENE XL/10 treatment
Good Atomized Spray Pattern after fuel is treated with DZL-LENE XL/10.
Fuel additive has been registered with EPA per 40 CFR 79.23 Registration Number 0285-0006.
Thanks for the followup info...;)
As for your tank storage I would put it in the shade if possible.. Also raise the front of the tank a couple inches. If the tank starts to rust inside you will pick up less of the rusty stuff as it will try to settle more to the low spot where your suction line is Not.
Later,x595
I also use power service have put it in #2 heating oil and have been fine up here in vermont
I'm glad you brought that up , because I have often wondered about using Power Service in my Kerosene 5 Gal. containers , which is used in my Kerosene heater ... I don't think there would be an issue , what do you guys think ???
Later,x595
Speaking of heating oil, seems like a storage tank for your tractor fuel wouldn't be any different than the tank for your furnace. I have mine with one end about 3-4 inches lower (above ground on a stand) and it has a drain there with a ball valve. If you were to get water in the tank from condensation, it will sink to the bottom and can be drained off from the low end of the tank.I usually fill my tank about this time of year, in preparation for winter, and by late spring is only about 1/4 full, if that (550 gal). I have a water separator filter on the line to the furnace, and it stops flow if it gets full of water or gunk. The only time I've had a problem with the furnace is if the filter clogs, better that than the injector in the furnace. I may get a cup or so of water in the tank over the course of the winter, drained out of the bottom of the tank.
I had never thought of using the Diesel service additive, I may give that a shot this winter. Maybe the cetane boost will keep me warmer. :biglaugh:
When I got to the Texas Refinery office and talked to a person that had bought computers from our store some years back he steered me to a product called DZL-PEP Artic. Seeing as how I was only going to use it for diesel and not gas he suggested this a better product. 1 liter of this stuff will treat 200 gallons of diesel to what they refer to a the platinum level. I am so far very happy with it.
Check their site http://www.texasrefinery.com/
1 - 17 of 17 Posts
