I finally got around to the loose steering on the H14. I thought the spring-pin hole was elongated because there was play between the wheels. I knock out the pin and it seems tight in both the spindle and sleeve. Now what? I check the ball joints and every single one is a bit loose, the tirerod between spindles is loose about 1/4 inch.
Five minutes later and Locktite on each ball joint thread and the steering is snug and true.
I have adjusted or replaced every single linkage, fluid, filter, belt, and wire on that tractor, short of tearing into the innards. I have no idea how the PO drove the thing across the yard.
I am sure there are more things I have not found, like that final loud backfire when I turn it off.
