1 - 8 of 8 Posts
Kish JD 318/420/430
Ok admins and mods, how do we delete conversations (old system - PMs) in order to control space used, we were only allowed some many????
Those limits were arbitrary and started when SimpleJohn was hosting due to size of his server I believe. Now that they are in the cloud not sure they care. Anyways go to your avatar in upper right and click on it, then open "Conversations" in the listing you can select the ones you want to delete, as soon as you select the first one this window will pop-up at the bottom:
2444454
15,000 +posts!
Is there still a 5000 word limit on PM's ?....always found that highly irritating,especially when you'd written a long reply ,then find out it wont let you post until you deleted a lot of it!..
Kish JD 318/420/430
Those limits were arbitrary and started when SimpleJohn was hosting due to size of his server I believe. Now that they are in the cloud not sure they care. Anyways go to your avatar in upper right and click on it, then open "Conversations" in the listing you can select the ones you want to delete, as soon as you select the first one this window will pop-up at the bottom: View attachment 2444454
I do not get that banner
2444456
Kish JD 318/420/430
That works, gives 2 choices left as possible rejoin if topic should come up again. Thank you Cat385B
1 - 8 of 8 Posts
