Not wanting to club it like a neanderthal, but this one is giving me a devil of a time. The pulley is either frozen on solid, or I am missing something. The ring on the face of the pulley is pinched on 4 sides, and I can't tell if it stays with the pulley, threads off or what. No set screws that I can find holding a keyway or the like. I did try a puller and all that happened was it began to bend the pulley so I quit. Looks like the bearing is held in by 3 slotted screws and a piece of thin metal, so I think the trick of removing Cub Cadet steering wheels is out where you put the nut back on and drive it through.
On the rear bushing, I've tried filling the cavity with grease and then later with compressed air to use the effect of forcing it out with pressure....no go on that one either. I see a little gap at the bottom and I may be able to come up with a custom slide hammer
Pretty well stumped at the moment, kind of frustrating because the S/G rebuild was cruising right along until now. Thanks for any help guys.
:howdy:
:howdy:
