1 - 9 of 9 Posts
Hello,
Today, I took a look at a 2003 Deere X475 with 62" deck and 530 hours. Right now, I've got a Kubota G1900S with 60" deck and 1230 hours. I just wanted to get some opinions about what I experienced.
The Deere X475 was nice and comfortable and was pretty clean. It started right up and ran smooth. When I took it for a test drive and cut some grass, I have to admit I was kind of disappointed. The ground was totally flat and the grass was maybe 6" tall or so (probably a little damp, but not soaked) and the tractor was definitely bogging down at anything even close to full speed. I almost think you would have wanted to cut at half speed.
I know that with my Kubota G1900S, I could have gone full speed and easily made it through this depth of grass without any bogging down.
Basically, I'm wondering if my experience is just the difference between a gas engine and a diesel engine, or a gas engine with 530 hours.
Even though the X475 was a good price, I decided to turn it down, as I know it just didn't have the cutting power of the Kubota G1900S.
Please let me know your thoughts. I'm trying to figure out if I should just stick with looking at diesels.
Thanks!
A diesel will always make more torque than a similar gas motor. They are also much more fuel efficient. You would need to look at the JD diesel powered garden tractors to compare apples to apples.
JD RULES
Hello,
Thanks!
Hi ensign ,
When you say full speed are you referring to ( pedal to the metal ) , because
that Tractor will do about 8 1/2 MPH , that's just to fast to mow grass
IMO ...
I do agree with amigauser post , but you need to try that Tractor at half
speed ( half pedal ) IMO ...
Later,x595
Hi ensign ,
IMO ...
Later,x595
Yeah, I meant pedal to the metal. The Kubota G1900S is rated at about 8 1/2 MPH too. I know it's not always best to mow at that speed, but I was trying to compare the capabilities of the machine to mine.
I have a G1900 with a 60" deck and I have never seen a mower that will cut tall grass, whatever, like it does. I think the deep deck gives it an advantage in heavy grass. It can discharge a lot of cuttings and keep on going.
USMC
You need to compare diesel to diesel and gas to gas for a comparison. I do things with my 24HP diesel that I wouldn't even attempt with a gas engine. It's all about the torque. slkpk
Anything wrong with your 1900? If not i would just keep running it unless you just want a new toy. Sounds like its a grass mowing machine!
As far a gas vs. diesel, in my limited experience, there is really no comparison between the two. If you own a diesel now, i think you will be disappointed with anything else.
Thad
Discussion Starter #9
Thad
No, nothing wrong with the 1900. I guess I was just looking for something newer and more comfy. :)
However, my experience definitely has me reconsidering just keeping the 1900.
Thanks everyone for your replies.
1 - 9 of 9 Posts
