1 - 17 of 17 Posts
Rich
I replaced my deck belt and a couple deck idlers about 3 hours run time ago. Started mowing today and smelled a funny smell, thought a belt but checked them both and seemed fine. Ran normal and cut grass for 1 hour with no problems. Pulling into the garage I found this half of a plastic disk that was burned in half and some clumps of melted plastic. I know it is from the X300. No idea of where it came from? It is about 3.5 inches in diameter and a lip around the inside edge. Anyone have an idea of where from or what it is?
Probably a plastic idler pulley. Bearing seizes, pulley doesn't rotate but belt keeps running and melts the pulley.
Rich
Good thought but no plastic pulleys on the X300 deck. No plastic on K46 either. May pull deck and look over
2449812
Sure looks like Urquells" pulley photo. Is there a drive belt idler?
Rich
Discussion Starter #8
Black so not cooling fan, Will pull deck and check drive belt pulleys tomorrow. Idlers look like plastic in parts diagram.
If that's a drive (trans) belt idler, which it probably is, then I'm surprised the tractor even moved!
One Spring I went to use my LA140 and it wouldn't move under its own power. After making sure the freewheel release lever was pushed in (that's thing #1 to check in that situation), I discovered that it had a seized drive belt idler.
Rich
Discussion Starter #12
Removed deck and found the rear drive belt idler fried. Just got a new and and replacing right now. Drive belt looks OK even after mowing for an hour with bad idler. Pictures later
Rich
Discussion Starter #13 (Edited)
Ok all fixed - changed the bad rear idler. Bearing still moved?? But had also bought the front idler but was having a tough time getting the belt off for that one and it looked and felt good so I left it on. Belt looked good and only 10 years old:) Pictures
Thanks all.
2449889
2449888
Long Time Thread Stalker
that belt has a lot of plastic residue on in now though. It probably slips a little bit under load
Rich
Discussion Starter #16
What you see in the picture is pieces of the melted plastic stuck to the belt. It popped off easily and belt looks great. Deere store is 15 minutes away:)
Glad you got it going. Mow on duder.
1 - 17 of 17 Posts
