Probably the line is clogged and not allowing it into the tube..the original tubing falls apart and leaks over time..I replaced it with fuel hose on a 318 I had
Probably the line is clogged and not allowing it into the tube..the original tubing falls apart and leaks over time..I replaced it with fuel hose on a 318 I had View attachment 2586260
Thanks for you suggestion. My tubes are clear and I was able to inspect them. They are not clogged.Probably the line is clogged and not allowing it into the tube..the original tubing falls apart and leaks over time..I replaced it with fuel hose on a 318 I had View attachment 2586260
Tried this yesterday, nothing happened. Tried it again today and it worked when I allowed the tube to hang below the discharge (don't know what it's called). Thanks!!If it is a clogged breather, disconnect the tubs above the sightglass. If fluid then fills the sightglass, it is an indication that the breather is the issue
