Hi all - recently purchased a completely rebuilt 54" blade to push snow with, and separately purchased a 314 to mount it on. I have a couple questions about the 314:
If you put too much pressure on the hydraulic lever on the left side of the tractor, it goes too far, like it is going over a lobe on a cam, and you have to force it back to zero position. Is there something missing that is allowing it to do this ? Something adjustable ?
Secondly, it did not come with front hydraulic outlets. The lines and couplers that run to the front are fairly easy to find, but I don't see where they would attach o the unit underneath the tractor. Is there a different unit required, or are they just T'd from the factory ? Do I just need to T or split each line ?
Lastly, the tractor seems to vibrate excessively at high RPM. The steering wheel just buzzes your hands. Bad motor mount / mounts ? Or something else. I've had other single cylinder Kohlers and don't remember this being a problem.
Thanks in advance for your input.
