1 - 2 of 2 Posts
Certified Master Tinkerer
I've never removed one so I can't tell you the answer. But lets back up a step - why are you removing it? If its because its only clicking when you try to start it the problem may not be the solenoid but the ignition switch. The contacts get dirty over time and do not pass enough current to engage the solenoid causing the clicking. A $25 relay kit from the dealer will solve that problem. Read here: http://www.mytractorforum.com/showthread.php?t=145721
1 - 2 of 2 Posts
