I have it on my new x500 and after the first cut I tried it and all it did was make a big mess and took off nothing and that was on a brand new deck. That was the first and last time I use it. Neat idea but IMHO it is not worth it.
I have it on my new x500 and after the first cut I tried it and all it did was make a big mess and took off nothing and that was on a brand new deck. That was the first and last time I use it. Neat idea but IMHO it is not worth it.What is the opinion regarding the deck wash systems the new decks have on them? Does it clean the bottom very well? I am thinking about putting one on my 54" deck on my 455 which has a mulcher kit on it. If it doesn't clean it well I would think you will just have very wet grass clippings under the deck which would create rust. My next concern would be water in the bearings.
Thanks,
Jerry
What a joke.What is the opinion regarding the deck wash systems the new decks have on them?
I think so,i have a new X300,the deck wash system is ********(sorry).I have it on my new x500 and after the first cut I tried it and all it did was make a big mess and took off nothing and that was on a brand new deck. That was the first and last time I use it. Neat idea but IMHO it is not worth it.
Here is the deal, if you are going to scrape anyway, running a hose through the port for several minutes makes the scraping job easier. Using the wash port and NOT scraping it, actually makes things worse, forcing water to mix with the dried grass and mud, then dry again makes it like cement!Well so much for the easy way out. Guess I will keep scraping.
Thanks for the comments guys.
They :beatdeadh don't :beatdeadh work :beatdeadh worth :beatdeadh a :beatdeadh ****. :beatdeadh A :beatdeadh total :beatdeadh waste :beatdeadh of :beatdeadh a :beatdeadh drilled :beatdeadh hole :beatdeadh and:beatdeadhhose :beatdeadh nippleWhat is the opinion regarding the deck wash systems the new decks have on them?
'Yep, got me a MowJack EZ'. Nice rig, but hard on the neck lying under the machine and working the deck with a putty knife. It's great for dropping the blades for a sharpening, can't be beat for that. BUT... I'll be moving to a larger machine (X749 or 2305) and even the MowJack Pro is not strong enough for that kind of weight (700lbs max load) and 1/2 the weight of a X749 is 650lbsa nice front end lift, three feet at least might allow a cleaning without deck removal?? anyone use that method?
I agree with slightly negative opinion of the deck wash. :sorry1: Now if I just knew how to properly prepare and store my deck for the winter I'd be set. :hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide::hide:Why Hodge ??? Has this come up before ???:bananapow:bannana::sidelaugh:ROFisgus::fing20::eck16:
Yeah:fing32: don't worry about it!!!!!!! as we get new members, these subjects are new to them. We just like to kid about it. Now you will too when you see it next :ROFI did not realize this subject has been beaten to death. Guess I need to get on the board more. I enjoyed the comments though. :sorry1:
