Deciding on a tractor for mowing a little over 1 acre (after I deduct the house and pool from 1.4 acre lot) of flat land with beautiful St. Augustine grass from lot line to lot line (we've only lived hear for a couple of months so haven't had time to ruin it!). About a dozen trees but each has a 6' mulched circle beneath which makes turning radius not as much of a problem. No roots to miss. I have two narrower areas to mow through measuring about 48" wide but there are ferns on the sides so if I mowed into them it isn't an issue. Now my question... I want as short a mow time as possible (duh) but not sure how large a deck to move to. I was think a 44" would be ok but willing to go bigger if I can. I have a wide shed to store it in with double doors opening to about 68". Want to mow, occasionally tow a spreader and airator and small cart not too loaded down. Is it possible to go TOO big on the deck? Are their other considerations I should take into account? Going from 44" to 52" mathematically decreases mow time by about 20% or so.Can you over do it and regret the huge thing later on?
Thanks for any comments!
