1 - 6 of 6 Posts
Hey all,
Where do you measure to find out the deck size? I'm thinking from blade tip to blade tip when blades are lined up perpendicular to the forward/aft line of the tractor. Is this correct?
Thanks.
Yup, deck size = "cutting width". So if you have a narrow gate or doorway you're looking to pass, take the "overall deck width" measurement.
Thanks guys.
It's a 212. And since I'm not very experienced with the different models and which decks come with which tractors I thought I'd ask here.
It's new belt time and I want to order one online. Our JD dealer and local Napa dealer seem to think their belts are all made of gold. So if I can find the deck size then I can order one online. (I hope.)
I did get a couple of tiller belts for my 300 online, half of what Napa wanted and they seem to be holding up. So I'll try the same place.
Oops, forgot. It has 3 blades.
So I went out to measure it and can't find my tape. That is ONE of my six tapes. I remember I kept buying them (cheapies) because I kept losing/misplacing them. Nothing has changed. AAArrrrrgggghhhh.
There were 2 decks with 3 blades made for the 200 series originally. The 47 inch deck has 2 deck wheels and the 46 inch deck has 4 deck wheels. I could get my 46 inch deck and now my 48 inch replacement deck through my 4 ft gate (opening is 52.5 inches) but neither one had a discharge chute mounted.
Reckon I have the 47" then since it had the 2 pulleys on the deck.
Thank you for that. Any chance you know the length of the belt? I assume it's a 1/2" wide one.
1 - 6 of 6 Posts
