Deck height problem
226 Views 8 Replies 3 Participants Last post by  gear442
I have a 2016 X584 48" deck with a powerflow which I mulch and bag in the summer and push and blow in the winter. I have no problem leveling the deck when I mulch but when I install the powerflow and try to level the deck I run out of threads when I try to raise the right side of the deck. The tires are set to 12psi in rear and 12 psi in the front plus I also tried 10 in the rear which didn't change anything. If I raise the pressures to high the ride is awful. The height bolts are hard to move unless I put a 2x4 under the deck to take the pressure off. This is the first year that I've had this issue and I'm the only one who uses this machine. Could the rocker shaft be worn out where the screw goes threw? I have striped out 2 adjusting wrenches and I'm perplexed. I bought this machine new and this is the first big issue I have had. I know how to adjust the deck because I have been doing it for 6 years with no issues. No broken rocker shaft springs that I can see either.
1 - 9 of 9 Posts
Could dirt be causing a problem w the adjustment nuts? I know for my Snapper, the adjustment nuts will catch and hold a bunch of dirt & water, and will wreck the threads of the threaded rod if I'm not careful to clean the dirt out before adjusting them.
I have clean them and I plan on changing the bolts when I switch it over for winter attachments. The bolts are just about impossible to turn with a load on them. It’s probably because I adjusted them a few times a year.
When I got my X728 the adjustment arms were hard to turn. I put them in a vise and then turned them adding never seize to the threads. I can spin them both by hand now when I need to.
This problem is where the bolt sits in the pocket of the rocker shaft, like it needs a bearing.
You are talking about these I presume:
Font Auto part Parallel Automotive window part Line art
Should be able to hit the nut and bottom with lube to help them adjust, you may have to lift arms part # 14 to expose the threads a bit though.
Thx but the bolts spin great with a 2x4 under the deck and the weight is taken off the bolts so it’s where the bolts sit in the metal frame is the problem. I was wondering if someone else had a fix.
I understand now! I hope you find some help for the problem.
1 - 9 of 9 Posts
